Solved
IAC lab 1 Issue (day 0)
  • 19 October 2023
  • 1 reply
  • 93 views
Badge
Hello , the mentioned url for the IaC lab 1 course shows a 6.7 controller being used, however , the SST installs a 7.0-controller which isn't working with the code in that github repo. As a result : terraform always fails.
Upgrading the source-version in versions.tf doesn't work
Please help me out
icon
Best answer by Seokwoo Sean Kim 20 October 2023, 16:22
View original
1 reply
Userlevel 1
Badge +2
If you set only the required Variables in the provider.tf file, it will work normally.
provider "aviatrix" {
  controller_ip = var.controller_ip
  username      = var.username
  password      = var.password
Use the password entered in the Launch Controller with the sandbox starter. username is admin.
For ip, check the public IP of the Aviatrix Controller on the awsec2 dashboard.
Reply
