Solved
ACE Automation - Lab 3 Issue with GitHub API action
  • April 4, 2025
  • 1 reply
  • 98 views
Dariusz_Terefenko
Forum|alt.badge.img+1
GitHub action doesn’t work as it gets stuck not able to do init
Run terraform fmt -check
6/home/runner/work/_temp/9c2fd51a-0563-4b86-b9ce-7955e6efdb0e/terraform-bin fmt -check
7
8Warning: The `set-output` command is deprecated and will be disabled soon. Please upgrade to using Environment Files. For more information see: https://github.blog/changelog/2022-10-11-github-actions-deprecating-save-state-and-set-output-commands/
9
10Warning: The `set-output` command is deprecated and will be disabled soon. Please upgrade to using Environment Files. For more information see: https://github.blog/changelog/2022-10-11-github-actions-deprecating-save-state-and-set-output-commands/
11
12Warning: The `set-output` command is deprecated and will be disabled soon. Please upgrade to using Environment Files. For more information see: https://github.blog/changelog/2022-10-11-github-actions-deprecating-save-state-and-set-output-commands/
Run terraform init
6/home/runner/work/_temp/9c2fd51a-0563-4b86-b9ce-7955e6efdb0e/terraform-bin init
7Initializing the backend...
8organization
9 The name of the organization containing the targeted workspace(s).
Any guesses why?
Best answer by Dariusz_Terefenko
If any of you have the same issue please use these:
https://github.com/hashicorp-education/learn-terraform-github-actions/blob/main/.github/workflows/terraform-plan.yml
Pretty much same way as described in Hashicorp documentation.
https://developer.hashicorp.com/terraform/tutorials/automation/github-actions
View original
