Solved
2 AWS Accounts - Same CGW?
  • Sep 11, 2020 2:44 PM UTC
  • 1 reply
  • 39 views
Forum|alt.badge.img
Hello Team,
Just curious to know that I am confused with 2 AWS accounts having 2 VPN Connections pointing towards same CGW.
It's possible but needs an explanation for the same as I was not knowing it before.
Is CGW end using VRF ? for same public IP?
Regards,
Kunal Shah.
Best answer by Mark_Noorman
Hi Kunal,
Not sure what your question is, but yes two accounts can have a VPN connection towards the same CGW. Also a VPN connection by default consists of two IPSec VPN tunnels for redundancy purposes. In case of two AWS accounts, you're talking about four VPN tunnels. CGW could use VRF, but not necessary.
Regards,
Mark
View original
1 reply
Mark_Noorman
Forum|alt.badge.img+3
  • First Officer
  • Answer
  • Sep 14, 2020 8:49 AM UTC
Hi Kunal,
Regards,
Mark
