Solved
How Are Admin Teams Automating Network Operations with Aviatrix?
  • Jun 16, 2025 9:59 AM UTC
  • 3 replies
  • 129 views
Hi all,
As part of a IT Admin team responsible for multi-cloud infrastructure.
I’d love to know:
Has anyone integrated Aviatrix with Terraform, Ansible, or using with Scripting tools like PDQ Deploy, Attune or Puppet for CI/CD platforms for network-as-code use cases?
Are there reliable ways to monitor and log Aviatrix activities from a SysOps point of view (e.g., Prometheus, ELK, or other observability stacks)?
We’re looking to streamline operations, reduce manual effort, and create a repeatable setup for managing secure and scalable multi-cloud environments.
Looking forward to hearing how others are approaching this in production!
Best answer by Alex_Weiss
Mohammed brought good answers for sure.
Also, when we work with our customer, we try to push our Aviatrix official terraform provider along with modules to accelerate deployment.
Browse Modules | Search: mc- aviatrix | Terraform Registry
backbone, mc-transit or mc-spoke are good modules
From a monitoring standpoint, Aviatrix Network Insight API is a source for Prometheus for events as well as performance.
Cloud Operations & Management for Cloud Networks | Aviatrix
You can also configure Copilot to export syslog that exposes Firewall logs if using Aviatrix Cloud Firewal and all sort of events.
Last but not least, we have preview integration with Microsoft Security Copilot to help troubleshooting VPN connections as an example, or gain insights into CVEs
Aviatrix and Microsoft Security Copilot | Microsoft Learn
https://www.linkedin.com/posts/aviatrix-systems_securitycopilot-ai-vpn-activity-7337857758202863617-K3Eu?utm_source=share&utm_medium=member_desktop&rcm=ACoAAAUY7qoBAaJ9bJowJvNaKRNzKe4KVkHGH_s
Hope that helps!
View original
MohammedBanabila
Forum|alt.badge.img+5
opions for IAC
using  pulumi   with  any terraform providerr
https://www.pulumi.com/registry/packages/terraform-provider/
Note : aviatrix  copilot  also do  observability  and visibility to all resources
speacial use case:
option for observability:  with ELK or prometheus/grafana
it require to web hook for api call fron  those tools  but  i think and suppose  notificatin  integration its may  possible ,   if you using kubernetes  you can deploy  those tools example ELK, prometheus/grafana and permission  for aviatrix api call   when they  visibili  and for   kubernetes  either self or full manged cluster
MohammedBanabila
createing repository    with  multiple environments for multi cloud networking ,observability
Alex_Weiss
Forum|alt.badge.img
  • Aviatrix Employee
  • Answer
  • Jun 17, 2025 7:27 AM UTC
Hope that helps!
