Solved
How do Aviatrix Gateways handle long-lived TCP connections?
  • January 16, 2025
  • 1 reply
  • 73 views
Forum|alt.badge.img
For Example:
a customer attempting to rule out aviatrix gateways as the cause for intermittent connection timeouts between SAP applications
Would the Aviatrix gateways have any configured TCP idle-timeouts or constraints with long-running TCP connection tests?
Best answer by MohammedBanabila
this explains how the controller process   aviatrix gateway keepalive
https://docs.aviatrix.com/previous/documentation/v7.0/building-your-network/gateway-keepalives.html
View original
1 reply
MohammedBanabila
Forum|alt.badge.img+5
