Question
How does Aviatrix implement encryption for east-west traffic between VPCs/VNets, and what are best practices for using Firewalls / Distributed Cloud Firewalls?
  • Sep 18, 2025 11:09 AM UTC
  • 2 replies
  • 315 views
Forum|alt.badge.img
How does Aviatrix keep internal cloud traffic secure when data moves between different networks, and what is the recommended way to use firewalls to control and protect that traffic?
MohammedBanabila
Forum|alt.badge.img+5
when  deploy   spoke and transit gateways  , they do  ipsec tunnel  communication  traffic flow which its fundamental of  end to end encryption ,  its uses  modes by default active/passive mode or  active/active which require you to enabled it
for firewalls   in east-west  architecture  ,  you can deploy as
  1. muli tier transit
  2. egress through firenet but require disable inspection
use this references which clear aspect of  east-west traffic or  north -south-traffic
MohammedBanabila
you can  inspect traffic based on tags or account id or region  along with smart group
