Mahindra Arjun Ultra-1 605 DI is a versatile and powerful tractor. The Mahindra Arjun Ultra-1 605 DI tractor is a testament to strong engineering and stable performance. Whether you are growing crops, hauling, or performing any other agricultural task, this tractor has been designed to handle all of them. The Mahindra Arjun Ultra-1 605 DI Tractor Price in India ranges from Rs. 9,36,250* to Rs. 9,57,650* and varies according to the features of the tractor.
Key Features of the Mahindra Arjun Ultra-1 605 DI Tractor :
- Engine: The Mahindra Arjun Ultra-1 605 DI is powered by a 4-cylinder, liquid-cooled engine that produces 55 HP at 2100 RPM. This engine produces a maximum torque of 217 Nm.
- Transmission: The Mahindra Arjun Ultra-1 605 DI transmission system is designed for effortless gear shifting. It has a synchromesh gearbox with 8 forward and 2 reverse gears. The side shift gear lever is comfortably placed for easy operation.
- Steering: This tractor comes with power steering.
- PTO & Hydraulics: The tractor delivers 48.8 PTO HP with a multi-speed PTO and offers 1800 kg hydraulic lifting capacity, supported by a fast-response system for smooth, precise operations.
- Tyre Sizes: Mahindra Arjun Ultra-1 605 DI rear tyre size is 716.9 X 28 and 14.9 X 28.
To explore more tractor models and find the right one for your needs, visit TractorKarvan – your trusted destination for everything tractors.
