Solved
Multi-Cloud Network Infrastructure as Code Course - Lab 1
  • November 1, 2022
  • 6 replies
  • 106 views
Forum|alt.badge.img
Hello, can anyone please help me with this part of Lab 1? (screenshot attached below)
I think it has to deal with the version setup. I tried so many steps but still having issues.
I'm using a mac. Help, please.
e.
Best answer by John_Smoker
SilEye This looks like you don't have the latest version of the IaC course code, compatible with controller version 6.9. Make sure you've cloned the latest code:
https://github.com/AviatrixSystems/ace-iac-day-zero
https://github.com/AviatrixSystems/ace-iac-day-two
View original
Did you make sure you have the latest provider Version defined?
terraform {
  required_providers {
    aviatrix = {
      source = "AviatrixSystems/aviatrix"
      version = "2.24.1"
Forum|alt.badge.img
  • Author
  • Cadet
  • November 1, 2022
Jeremiah Sholes  Yes, I tried it but having a constraint error.
SilEye you might want to try only a specific newest prover version and re init after
John_Smoker
Forum|alt.badge.img+3
Forum|alt.badge.img
  • Author
  • Cadet
  • November 1, 2022
Jeremiah Sholes Thank you. I appreciate your help.
Forum|alt.badge.img
  • Author
  • Cadet
  • November 1, 2022
Hey John Smoker,
Thank you for providing me with the latest version of the code. I got the Plan working fine now.
I have other errors at the Apply level, but I'll try to figure it out myself before asking for help. ðŸ˜…
Thank you much appreciation!
