Solved
Overlap-CIDR Between Two VPCs
  • Sep 27, 2020 9:37 AM UTC
  • 1 reply
  • 50 views
Forum|alt.badge.img
 For DR purpose and features like
 - Fail over
 - Fail back
- DR Testing
 we need to clone source VPC (10.0.0.0/16- us-west1) to another VPC (10.0.0.0/16- us-east2) with same CIDR. Is this OVERLAP-CIDR support is available.
 TGW etc.. not support CIDR overlaps
Best answer by Shahzad Ali
Yes Aviatrix does support overlapping. All the use-cases you listed are cases we see from other customers as well. There are different design possibles based on your requirement. Start with this doc and see if it fits your needs. If not, we can have a Zoom session with our SE as well.
https://docs.aviatrix.com/HowTos/site2cloud_faq.html?highlight=overlapping%20IP#are-there-any-tech-notes-on-solving-overlapping-ip-addresses
View original
1 reply
Shahzad Ali
Forum|alt.badge.img+6
  • Commander
  • Answer
  • Sep 28, 2020 1:07 AM UTC
