Solved
this error come when deploying a resource with  pulumi using python
  • May 15, 2024 2:58 PM UTC
  • 4 replies
  • 121 views
MohammedBanabila
Forum|alt.badge.img+5
i did deploy controller and copilot at aws console manually.
this error come when deploying a resource with  pulumi using python for lab single cloud multi region
aviatrix:index:AviatrixAccount (myaccounts):
    error: 1 error occurred:
        * controller version validation failed: current Terraform branch does not support controller version: UserConnect-7.1. Please go to 'https://registry.terraform.io/providers/AviatrixSystems/aviatrix/latest/docs/guides/release-compatibility' for version construct instructions
how to solve it ?
Best answer by Matthew_Gillespie
While I’ve not used the Pulumi provider before, it looks like it stopped development over 2 years ago and does not support newer versions of the Aviatrix controller.
6.9 is no longer a supported version of the Aviatrix Controller.
With each new version of the Aviatrix controller, you’ll find an updated Terraform Provider. You can determine which Terraform provider matches your Controller version by looking at that page.
Did you have reservations against using Terraform for automated deployment? If not, I would recommend leveraging Terraform as the provider is kept up to date.
View original
MohammedBanabila
 i   checked from  pulumi aviatrix provider   repository at github
using pulumi aviatrix 0.0.11 · Issue #3 · astipkovits/pulumi-aviatrix (github.com)
response was  This Pulumi provider is based on the Aviatrix Terraform provider version 2.24.1. This version is compatible with Aviatrix controller version 6.9.161. Your controller is version 7.1.x which is not supported by this Pulumi provider, thus you see this message. For reference, see the Controller compatibility part of the readme.
MohammedBanabila
can be using the controller of particular version only and do update manually when its need its patches to be updated or should disable auto update   for controller   will be recommended?
MohammedBanabila
no reservation on terraform. but due to trade law
This content is not currently
available in your region.
Please see trade controls.
  i can't access it and only option to use terraform or terraform cloud, it requires to use vpn  so i  access terraform cloud
