Question
using aws application load balancer
  • Jun 3, 2024 5:54 PM UTC
  • 2 replies
  • 56 views
MohammedBanabila
Forum|alt.badge.img+5
using single cloud with multi-region us-east-1 and us-east-2
can be do curl command to webserver which is in us-east-1 through  spoke
can be identify the ALB with client IP address of bastion ip address that come from spoke at us-east-1
Katie Holms
Forum|alt.badge.img+7
  • Commander
  • Jun 5, 2024 10:44 PM UTC
Hi @MohammedBanabila , can you please clarify your question?
MohammedBanabila
 use  aws application load balancer in region us-east-2 to register webserver
from bastion instance in region us-east-1 using curl command to get http request from private ip address of webserver port 80 when 1 access bastion instance through ssh port 22 in region us-east-1
and then type sudo curl http://private-ip-address-webserver in region us-east-2
if reference it spoke security group in region us-east-2   to be referenced as source for security group of webservers which at private subnet
as lab will it work ?
as mentioned at   lab-aviatrix-ace.docx   for training lab
