Solved
Warning on Terraform during Infrastructure as Code certification labs
  • Feb 7, 2022 12:31 PM UTC
  • 2 replies
  • 41 views
Is this something I should be worried about? Am I doing something wrong in the Lab (1) or has terraform undergone some changes since the course was written?
Plan goes ahead anyway, these are just warnings. Is there a way I can fix them?
Best answer by Frey_Khademi
Hey Timothy Rudd - thanks for reaching out.  That warning can be safely ignored as it is warning you that in the next release, that specific attribute will be deprecated.  So once we move to the next release (and you upgrade your terraform provider), that warning will go away.
Cheers
Frey
View original
Forum|alt.badge.img+1
  • Aviatrix Employee
  • Answer
  • Feb 7, 2022 2:03 PM UTC
Cheers
Frey
Thanks, just moved on further in the course and saw they addressed this issue too.
cheers
