We have deployed the solution for aviatrix hybrid edge spokes in azure cloud + on prem DC
Hybrid edge controller are sitting in the azure VNET ,dedicated for the controller
While edge spoke gateways which communicate to these controller via IPSEC tunnels are sitting in the on prem DC
We have see the problem , edge spoke gateways create these IPSEC tunnels using the private underlay links between on prem dc and the azure express route connections , also the same underlay link are being used for communication or the updates between controller and edge spoke gateways
Further the edge spoke gateways sitting in the ON PREM dc have BGPoLAN connection and advertises the overlay routes to on prem connection
We have two on prem DC , 4 sets of edge spokes in each DC
On prem DC are further connected to the Colos (On prem DC1 to Equinix Colo ) & On prem DC2 to Cologix Colo
Problem
During the outage of the link between on prem DC 1 to the Equinix Colo
Both data plane and mgmt plane connection gets disconnected , due to which the routing update for the attachments between hybrid edge transit gateways (controller by the controller hosted in azure vnet) and edge spoke gateways doesnt go through and the traffic doesnt failover to the onprem DC2 + Cologix Colo
We are thinking what solution can be provided by aviatrix for the auto failover for the edge spoke gateways data plane between the two colos
did you use those  options:
advanced routing enable and vrrp with edge
We dont want much dependency on the on prem dc team
plus we have only single link connecting on prem dc and colo in equinix
when it goes down , we lose the mgmt plan to edge spoke gateways
plus we dont want to have the separate DIA
options: A
  1.   have multiple edges  for high availabilitytha]
  2. note: with equinix    ,   the  edges  has  8 interfacesiwan interface recommend to  use 4 interface, only 1 lan  interface, i mgnt interfaces  which hardware limit
        3  connect multiple mgnt interfaces  with controller
         4. multiple lan  interface connect  to  on prem  dc router
Reply
