Solution Brief
https://www.fortinet.com/content/dam/fortinet/assets/alliances/sb-aviatrix-cloud-security.pdf
Technical Documents
- FortiGate Deployment Guide in AWS
- FortiGate Deployment Guide in Azure
- FortiGate Support in GCP
- Bootstrap Configuration Example for FortiGate Firewall in AWS
- Bootstrap Configuration Example for FortiGate Firewall in Azure
- Branch/DC Connectivity from Aviatrix Transit to FortiGate over Internet
- FortiGate support with Aviatrix’s AWS GWLB Management and Control
- Branch Connectivity from Aviatrix VPN Gateway to FortiGate over Internet
Webinars/VOD
Aviatrix and Fortinet SD-WAN integration in minutes with Terraform!
Aviatrix FireNet with Fortinet
Terraform Resources
https://github.com/terraform-aviatrix-modules/terraform-aviatrix-aws-sdwan-fortinet
